Reply To: Changing fabric on Beovox S120
#7113
Dillen
  • Topics Started 1
  • Total Posts 39
You get the new fabric in the same way. Pressed in using the alu trim.
Clever? Yes.
Elegant? Yes.
Easy? No.
I have had a little success first glueing the new fabric in to the ridge on one side,
then, when set, work to the opposite side etc. and fit the alu trim last.
