July 28, 2022 at 6:45 am
#7109
The drive stops because no tape motion is sensed.
– Bad belts
– Bad motor
– Lack of power to the motor (bad fuse)
– Seized take-up reel
– Cracked solder joints at the connector to the drive
– Broken off lead for the motion sensor
– Any combination of the above.
If it happened after shipping, I would check if the motor is running when the deck is
out of standby. If it doesn’t check the fuse on the regulator board – and its holders.
But I agree, the seller should help you with this or take it back.
This reply was modified 1 week, 6 days ago by
Dillen.
