Reply To: Connect Beogram 4400 to a CD Player
#7090
Millemissen
  • Topics Started 5
  • Total Posts 145
As far as I remember the BM4400 has 5-pin input connections (one for Phono and two for Tape).
Basicly you can use any CD player – in some cases you’ll have to use an adapter (R/L to DIN).
If you want vintage B&O….go for a CDX/CDX2 – which one is better the vintage specialist here may tell you.
There you have options for controlling directly on the device.
