Reply To: BeoLink PC2 and Beo4 Remote on MacBook Pro Early 2015
#6994
matador
  • Paris France
  • Topics Started 20
  • Total Posts 177
If you connected BL3500 or 2000 to the PC2 by masterlink then ‘yes’, with limitations – it would be set up as if the Beolab was in a Link Room. You wouldn’t need an IR sensor for the PC2 because you’d put it in option 0 and control it from the BL2000/3500 – Beo4 would be fine for full control.
This is interesting: The that old saying telling A Beolab 3500 can be used standalone with a 1611 converter only is wrong?
