Reply To: BeoLink PC2 and Beo4 Remote on MacBook Pro Early 2015
#6987
Guy
  • Warwickshire, UK
  • Topics Started 4
  • Total Posts 202
the PC2 could be used with a Beolab 2000 or -3500?
If you connected BL3500 or 2000 to the PC2 by masterlink then ‘yes’, with limitations – it would be set up as if the Beolab was in a Link Room. You wouldn’t need an IR sensor for the PC2 because you’d put it in option 0 and control it from the BL2000/3500 – Beo4 would be fine for full control.
However you wouldn’t be able to ‘activate’ the BL2000/3500 from the computer (i.e turn it on/off). You should be able to control playback once it is running however – eg advance tracks or change N.RADIO stations.
(EDIT: In effect you would be using the Beolink PC2 as an audiomaster – hence it should be set up as such in the options menu.)
  • This reply was modified 3 weeks ago by Guy.
