July 23, 2022 at 9:10 pm
#6966
Have a closer look, pretty sure all looms will unplug, there is one tricky loom plugged in under an RF shield which can be either unsoldered or pried up at one end, then un-plug the loom, Be careful not to bend the shield out of shape too much ( it stops the sliding door opening if it’s not put back in original position)
good luck, I’m going to do some work on a 9500 soon which should be very similar I can take some photos if it helps.
Regards Brad
