Reply To: Beocenter 9300 Tape Deck Belts Replacement
#6946
Beowolf
  • Topics Started 2
  • Total Posts 5
Thanks for your reply, Andree. The video is very helpful!
Do you happen to have any advice on the best way to remove the tape deck from the unit so it can be worked on more freely away from the unit? Some of the cables have clips that can be easily removed to free the deck from the PCB, but there is one group of maybe 8 or 10 wires that are soldered to a connector on the PCB which are the main issue.
Unfortunately, I didn’t think to take pictures of this when I had the unit open, but I was working on it still connected to the PCB, which was a bit limiting for working on the deck.
Thanks again!
