Reply To: Beolab 5 and Macbook Pro
#6860
mihnea
  • Topics Started 3
  • Total Posts 7
Millemissen – great!  I do use a B&O remote for the volume, it doesn’t bother me.  I did read the review, and it’s a little bit over my head (!), but I understood the main points.
Presently, I use a digital coax to optical converter, and then I plug the optical into a CalDigit dock, which I then connect via Thunderbolt with my Mac.  Your solution is much more elegant, and it’s one box versus two boxes, and it might have other uses, too, like headphones, etc.  So I’m going to go ahead and buy one and try it.
Unless you tell me there are better DACs…
