Reply To: Beolab 5 and Macbook Pro
#6852
mihnea
  • Topics Started 3
  • Total Posts 7
Thank you, Millemissen.  All I could see from the pictures are outputs.  Does this thing have a digital coax audio input, so I can connect the speaker cable directly into it?  I assume that it has an USB output to connect into the MacBook, right?
If not, how did you connect Beolab 5 speakers to it?
