14 July 2022 at 19:29
#28314
Well…sadly…replacing the servo belt and cleaning the spindle didn’t fix the issue. I guess replacing the caps is next. Seems odd that after operating the << & >> keys and watching the tomearm travel back and forth accross the platter for a few minutes would get the unit to perform normally. If the caps were bad, they’d always be bad, no matter how long you moved the tonearm back and forth. That’s what made me think is was a mechanical issue.
Anyways…anyone know where to get a replacement set of capacitors in the US?
