Reply To: Beocord 6500 (type 4938) problems
#6754
jahmadeus
  • Topics Started 1
  • Total Posts 3
I was not implying that the LM324 was controlling the motor. Simply giving background. I replaced the IC and resistor due to visible heat marks on the components and board.
The two spindles seem to rotate easily by hand. The hang up and eventual shut down usually seems to happen before there is any movement from the ff/rw/play motor. However, I will disassemble them and give them a good cleaning and see if that can help the situation.
Thanks for the response
  • This reply was modified 3 weeks, 6 days ago by jahmadeus.
