Reply To: Beogram 8002 cleanup
#6715
WallyGator
  • Topics Started 1
  • Total Posts 6
The belt on the TT is original so I bought a new belt.  Should get here next week.
When pressing play on the TT, the tonearm moves out slightly but doesn’t reach the edge of the record.  It then returns home and shuts off.  If I use the < & > keys to move the tomearm back and forth across its entire range a few times, the play button begins working correctly.  It’s almost as if it neeeds to stretch & warm up before exercising.  Seems to work OK after a “warm up”.
I’ll be carefull with any cleaner I use.
