Reply To: Beocenter 8500 – Cassettedeck stopped working
#6709
spassmaker
  • Topics Started 3
  • Total Posts 36
Hi Bert
You mentioned the small Motor on the back, please check if the plastic gearwheel is tight fit to the motorspindle, had already two which were cracked and slipped through / did not really turn the other gearwheels completly, so the drive got stuck in some unusual state, sometimes worked sometime only fast forward and so on.
If cracked you could glue it back in place with superglue, worked fine both times.
Kind regards
Christian
