Reply To: 2nd hand Beocord 2000 Deluxe – Critical points to check
#6706
omminp
  • Topics Started 0
  • Total Posts 4
Hi and thanks for the videos.
The noise doubles in frequency and becomes more intrusive as the speed increases.   The idler is causing the noise, a bit annoying for you.  Maybe worth swapping the idlers in the short term as suggested by chartz.
The belt is not likely to be a problem provided the uptake spool works ok when playing a tape.
Post a photo when you get it all back together.
Regards Peter
