Reply To: 2nd hand Beocord 2000 Deluxe – Critical points to check
#6700
chartz
GOLD Member
  • Burgundy
  • Topics Started 0
  • Total Posts 62
Yup, the idler is definitely the culprit for this noise. The usual flat spot plus hardened rubber. Nothing to be done here, just have it redone by a competent company. All three have to be done, by the way.
Meanwhile, you can swap the noisier one with the one at right.
Never mind the belt, but yeah, it’ll need to be replaced too. It’s a bit loose.
  • This reply was modified 1 month, 1 week ago by chartz.
