Hello Beoworlders,
Chartz and Omminp, thanks for your precious informations.
I opened the set and cleaned what I could, including the heads which seem to be OK.
I did not put oil on the idlers, as I don’t know which kind of oil to use.
The exchange of capacitors is unfortunately out of my competence.
The connection from Beocenter to the Radio input on the BC 2000 works.
I kept a connection from the Line socket to an USB soundcard and tested the recording on a laptop. Test was successful.
Good surprise, a small envelope containing the schematic is stuck inside of the bottom plastic case.
2 problems remain:
1: I cannot find how the chassis is held on the wooden frame. I found one screw on the right side, underneath the headphone jack but could not find anything on the left side.
So if I place the set vertically, the chassis tends to get out.
Unfortunately the service manual available on the old site is in German and I don’t speak this language.
2: The set is rather silent on low speed, more noisy on middle speed and supersonic on high speed.
It does not work when placed vertically.
Could a video help someone to diagnose where the defect stands?
Thanks for your help,
Yann.
