Reply To: Beocenter 8500 – Cassettedeck stopped working
#6677
Die_Bogener
  • Topics Started 1
  • Total Posts 39
Desolder/remove TR17.
Use a seperate power supply and send 14V with limited current instead TR17… and check wether there is a short in the system or why it needs so much power.
Dont blow some transistors, use a regulated power supply instead. Try less than 14V and limitied current…
