July 5, 2022 at 10:07 pm
#6566
Hi trackbeo, Yes, I accepted the new update manually, I had to update each Emerge separately as they were set to have auto updates turned off. All is working fine at 10017 software level, with the auto updates still disabled after this manual update. Kind regards, Steve.
Thanks, @Steve, I understand that you were not willing to go through the hassle of creating another account and adding your products to it. So I sacrificed a BeoSound 1(2.gen) to test. Result: The iOS app (4.0.3.xxxxx) updates the firmware of a product added fresh to a new account, regardless of internal settings it may have had from a previous account. The iOS app does not ask if it can update the newly addded product, it just does so. Caveat Usor.
