Reply To: Need help sourcing a BEOGRAM CD 50 laser
#6470
Dillen
  • Topics Started 1
  • Total Posts 36
When you press play, Beogram CD50 will:
Move tray in.
Check for presence of disc.
If disc is present, lift disc to engage with motor spindle hub.
Run trackingmotor to make the laser carriage reach the track 0 switch.
When track 0 switch is reached, start disc motor.
When disc motor is running, switch on laser and read TOC.
Etc…
Your deck stops at moving the carriage.
It seems the carriage is all the way out – it should move all the way in. (CD’s play from inner tracks out).
You tell that you have taken it all apart and put back togehter. Are you sure you got the tracking motor polarity right?
(For reasons unknown to me no longer Dillen)
