Reply To: 2nd hand Beocord 2000 Deluxe – Critical points to check
#6311
chartz
GOLD Member
  • Burgundy
  • Topics Started 0
  • Total Posts 61
Yes, the Bogen heads can be defective. Not worn necessarily but electrically defective. They don’t like old capacitors at all, so if you find an old machine that hasn’t been powered on for ages, don’t try it. Replace capacitors on playback and record circuits then go ahead.
The BIG problem in those decks are the idler wheels. Normally they should be completely silent, but after all this time they harden and become intolerably noisy. They really ruin the experience, hence my preference for Revox machines over Beocords or Uher machines, which were good, but had only one Papst motor.
