Reply To: B&O Century CD problem
#6304
Die_Bogener
  • Topics Started 1
  • Total Posts 40
The radio is hardware coded depending to the area/country… usually the cpu should read the correct type of tuner board and configure the software.
Either there is a software bug… or the type cannot be read or the lithium cell is dead. This happens also when some caps in the power supply have problems.
