Reply To: 2nd hand Beocord 2000 Deluxe – Critical points to check
#6303
omminp
  • Topics Started 0
  • Total Posts 4
I have found that the critical issue with these machines is the heads.  It seems the original Bogen heads have a high failure rate, all but the erase head which seems to be a survivor.  Often the other heads will be open circuit (both or 1 channel).  Original heads are not readily available, and if they were they would be suspect given the time since manufacture.
The other known issue (fast winding) may not be a problem if that part is working.
