June 29, 2022 at 6:27 pm
#6298
I wanted to check the caps first to be sure the problem is there but understand that they need to be disconnected from the board first? If the problem is 100% caps then indeed makes sense changing them all. Another problem I have is that the radio stopped scanning FM and it only scans MW and SW although the model is EU and only has FM tuner. Do you think this might be from the caps as well?
