Reply To: Need help sourcing a BEOGRAM CD 50 laser
#6252
chartz
GOLD Member
  • Burgundy
  • Topics Started 0
  • Total Posts 61
You can’t. But are you certain that the laser is toast? Very unlikely.
The laser head should be near the centre – its normal parking position – and the end position switch engaged.
Investigate this. Try to manually slide the laser sled towards centre (done that?, it isn’t clear) and see what happens.
  • This reply was modified 1 month, 2 weeks ago by chartz.
