Reply To: MMC20 Genetic manipulations…
#6197
matador
  • Paris France
  • Topics Started 22
  • Total Posts 189
Thank you Chartz,
If I understand well, in SP’s the cantilever is “plugged” on the prong that protude from the cross, right? Then you would just need to “plug-in” a new hollow cantilever over it isn’t it?
Then how do you take out the cross and rubber part out of the SP shell? Is it glued or do you just need to push?
And to remove the previous cantilever you just need to pull it?
  • This reply was modified 1 month, 2 weeks ago by matador.
