Reply To: MMC20 Genetic manipulations…
#6163
matador
  • Paris France
  • Topics Started 21
  • Total Posts 181
Given the way I’ll be using this turntable (mostly with my 78 RPM disks) a DIY pickup rebuild would not be crazy.
Hi Geoff and thank you for your kind words.
I’m not sure of that but I think 78 RPM records are made of a softer material than modern records. Not a problem when the needle is new, but I’ve read scary things when the tip starts to wear. And sapphires wear quickly (less than 100 hours against 1000 for a diamond, I’ve read), even more when the tracking force is high like it was in old turntables.
I can’t find and old advert that says something like “worn stylus are chisel for your records” but in all case you should maybe check before dropping any needle on your disks.
Regards.
