June 24, 2022 at 10:44 pm
#6136
- Thanks again David you gave me the courage to
pull a bit harder 🤣 the Penta 1 doesn’t have the screws the first display cover is the same the next screen cover also unclips with 3 small pegs “brittle” then the digit board hinges up slightly and unplugs downward and then the other boards slide and unplug the same or I suppose the whole thing should just pull out as one, but you would be relying on the three brittle clips 🤔
thanks again regards Brad
