June 24, 2022 at 7:19 am
#6111
Your original black foam is exactly the same poison foam as in the old BL8000 and damage your BL6000.
The new white foam in my pic makes your BL6000 happy again.
I dont know if an other foam better or the same working in your BL but I think the original is the best. When your dealer would your BL repair so he takes the original from B&O.
You can try an other dealer to send you the spare foam. Maybe he is more flexible with you.
good luck
