Reply To: Connecting BS3000 to BS Core
#6088
Carolpa
  • Topics Started 3
  • Total Posts 31
Hi Carolpa, Thank you so much for your elaborate advice! Following your steps, I got it working. Would it also be possible to use the Beo4 to control the volume? Right now, I can switch tracks with the Beo4, but for volume I have to revert to the B&O app. Thanks again! Joeri
The volume command given is processed by the BS3000. But the speakers are connected to the Core. So this is normal behaviour. If you have the correct Core you can connect an IR-eye. Then it should be possible to use the Beo4 for volume control.
But be aware: then you must set the BS3000 in option 0 otherwise you could end up in a mess with controlling the system.
