June 22, 2022 at 7:39 pm
#6079
Basicly it makes the A6 visible and reachable on your home (wireless) network.
Please have a look here:
https://support.bang-olufsen.com/hc/en-us/articles/360049500212-Beoplay-A6-first-time-setup
It should be fairly easy to set up in the Bang & Olufsen app.
Note: if the SW is very old, you might have to use a wired connection in order to get the A6 uptodate.
You can choose the A6 (the Airplay connection) in the setup of the ATV in order to have sound from the ATV4 through the A6.
P.S.
Generally it will be better soundwise to use Airplay instead of Bluetooth
This reply was modified 1 week, 5 days ago by
Millemissen.
Millemissen.
