Reply To: A question for Geoff Martin on BL8000 Damping…
#6035
mojofml
  • Topics Started 2
  • Total Posts 7
Thanks for your great write up. I’m fixing up my BL6000 and the foam has completely fallen apart as well. I will check with my local B&O store whether I can get replacement foams (unlikely), but if not can anyone suggest what alternative foam I can use? Ie thickness, density, material, etc. Greatly appreciate your advice.
  • This reply was modified 2 weeks, 1 day ago by mojofml.
