June 20, 2022 at 9:21 am
#6020
The lid sometimes works but then the voltage is around 9 volts on the motor (slow working was below 7 volts measured. But I have just been re soldering the Motor Control unit at the parts on the cooling plate mounted . And slow working because without anything further mounted . But in slow time it’s plays the cd and is doing his moves from one cd to the other . So maybe it’s solved now for the time being ? And maybe a problem that is happening more on these older equipment nowadays ?
