Reply To: Loud noise when turning on Beocenter 2002
#6012
Mark-sf
Beoworld Member
  • Topics Started 0
  • Total Posts 57
Are you certain it was R201 3.3K ohms that was burned? I ask because that is a series input resister to the power amp IC and i can’t see it getting the current to “blow” it. If that is the resister, could it have been cracked instead? As to the noise can you describe its character. Can you check if you are getting a DC voltage on the output with the speakers disconnected?
