June 20, 2022 at 7:22 am
#6006
Hi
About 1/2 hour is quiet a long time…
Does the Beosound react normal to operation with the pushbuttons on the unit itself in the first minutes?
Had quiet some strange behaviour when the glasplate is not mounted or the small IR detection partsĀ (small triangle plexiglas) and the glasplate are not clean.
Clean the glasplate from outside AND inside and clean the small plexiglas parts, maybe you’re lucky.
Sounds strange but….
Regards
Christian
