June 16, 2022 at 8:37 pm
#5940
The Beosound Century was configured depending on market area and can be checked by the four digit type number:-
- Type number 2651 is EU countries excluding UK and had FM Only
- Type number 2652 is UK and had FM, LW, MW
- Type number 2653 is US & Canada and had FM, LW, MW
- Type number 2654 is Japan and had FM, LW, MW
If you have a type number 2651 then MODE change will not work. Please check type numbers. If it is one of the other type numbers then the instructions you were using are correct. See below for confirmation.
