I’ve managed to get the transformer and cables from Steve, thanks again for your help!
In case anyone had the same question as me, while the transformer only states 110v output, it still works fine with the unit which states 120v.
I did notice another problem though. Once I plug the power to my Beosound 4000, the light stays on, and also the CD player won’t play (the CD won’t spin). The loading/unloading works fine, and the glass opens/close as normal. Any ideas please?
**Edit: Sorry I should’ve did a search prior to posting this but I was in a bit of panic 😀
It seems this is a bit of a common issue and there are many videos online talking about this and the way to fix it. Looks like I can source the rubber and replace it without too much difficulty!
I have another problem. Having started listening to music for about 15 min or so, I started hearing some buzzing noise out of the speakers. These haven’t been used for a long time, see the pics below I don’t know how to describe the part, but i’m guessing the rubber had dried up or something and it started to fall off. Is this self-repairable, or what can I do for this? hoping for some good news, thanks!
This reply was modified 1 week, 5 days ago by
mojofml.
mojofml.
mojofml.
mojofml.
mojofml.
mojofml.
mojofml.
mojofml.
