June 16, 2022 at 5:27 am
#5915
I would check the 12v supply. You may have bad caps at C3 or C4. Make sure you have a clean 12v at the solenoid. TR6 regulates the voltage to 5v for the motor so it would not cause this issue. There may be 120Hz noise on the 12v line.
