June 16, 2022 at 2:15 am
#5913
Hello,
no, its not what you are referring to !
A bit tricky to describe but the piston moves freely when it moves.
what however happens when the lift is activated is that the piston moves forwards and backwards very quickly which generates a rattling noise via the lever arm “connected” to the gear wheel that operates the up/down lift.
does that explain it any clearer ?
ALF
