June 13, 2022 at 6:55 pm
#5849
Hi ALF,
Can you disable the Beomaster 8000 IR receiver circuit to verify the problem doesn’t occur when the remote control receiving circuit is out of the picture?
It will require leaving it disabled for a good period of time (maybe a month). Then verifying the problem returns after re-enabling the IR receiver.
John
