June 11, 2022 at 5:33 pm
#5804
Sorry to say it – it seems that your converter is not properly configured.
What you ask for should be possible.
Back in the glory days of the converter B&O made a little box, that can provide the ML with power…..for those who still had a ML-based link setup, had a new NL-based tv and wanted to ditch the old audiomaster.
You should be able to do the same with the 1611 converter.
https://archivedforum2.beoworld.org/forums/t/16217.aspx?PageIndex=1
Personally I’d keep the 3200 and hide it away, if needed.
Maybe someday you want to play CD’s again or use the AUX for a turntable 😉
This reply was modified 2 weeks, 3 days ago by
Millemissen.
