Reply To: BV 6-26 Speaker Grill foam
#5768
Tignum
Beoworld Member
  • Netherlands
  • Topics Started 0
  • Total Posts 25
Hello stotty1111, mine had the same issue (and probably many more speakers with such a metal grill like BeoLab 7-1 etc.). I decided to just take it off, clean the plastic frame and re-attach the metal plate with a good quality narrow and thin double sided tape.
