Reply To: 7700 very low sound output
Home Forums Product Discussion & Questions BeoCenter 7700 very low sound output Reply To: 7700 very low sound output
#57288
solderon29
GOLD Member
    • Topics Started 3
    • Total Posts 30
    Looking at the connection panel,you should see a round Din socket with light brown plastic plug in it,but with no wires!!!
    If you can see the socket but not the plug,then thats what’s causing your problem .
    That socket is a port for an auxillary in/out device,eg.a mixer or equaliser,but people often think it’s another input and take the plug out,to connect something like a Bluetooth receiver,which would work,but also interrupt the signals for the other sources.
    If your plug is missing,you can source one from the Beoparts shop,that sponsors this site.
    Nick
