Reply To: Beomaster 2200 – Line Out
Home Forums General Discussion & Questions Beomaster 2200 – Line Out Reply To: Beomaster 2200 – Line Out
#57287
solderon29
GOLD Member
    • Topics Started 3
    • Total Posts 30
    Are you connecting to the correct pins on the tape output?
    It should be pins 1 and 4.
    The tape output level is rather low on these units (100mV),but there is scope to increase the output by altering the value of some resistors inside the unit.
    Are you confident in opening the unit and doing some soldering?If not,entrust the work to someone else.
    Nick
