Home Forums Product Discussion & Questions BeoSound Beosound 4 and 5 together? Reply To: Beosound 4 and 5 together?
#57241
Guy
    • Warwickshire, UK
    I would probably look for a later DTV Beo4 (not the navi version) so you can put it in permanent link mode.
    I can use my Beolink 1000 for that (Link>Shift>Radio) but my Beolink 1000 does not belong in that room, and it has other limitations when using it with a Beolab 3500.
    What limitations?
    So, would a Beoremote 1 work for this?
    Do you mean the early Beo1 like this? (In which case the answer is no!) Or the later more modern Beoremote One, which according to the manual (page 16) has a Beo4 LINK mode.
    Beo5 or 6 would also work for LINK, but can be quite complicated to set up.
