Reply To: Connecting BeoLab2 to AV 7000
Home Forums General Discussion & Questions Connecting BeoLab2 to AV 7000 Reply To: Connecting BeoLab2 to AV 7000
#57044
stefan
    • Topics Started 0
    • Total Posts 9
    why not connecting your front- and rear speakers to the existing Powerlink sockets?
    You can connect your BL2/BL11 to the FRONT powerlink output and your front speakers to the BL2/BL11 PL outputs.
    Connect your rear Beolabs to the rear PL outputs.
    Dolby surround is an analogue 4 channel surround system using old Dolby Pro Logic technology.
    You have 3 front channels (L C R) – for the center channel the AV7000 got a powered mono output.
    The rear channel is a mono channel, that reproduces frequencies from 100(!) – 20000 Hz – there is no dedicated LFE(sub) channel.
    Connect your BL4500s to the rear channel as described – You will have 5 soundmodes:
    S1 – mono (center)
    S2 – stereo (LR front)
    S3 – Dolby 3 stereo ( LCR)
    S4 – 4 channel stereo (stereo front and rear)
    S5 – Dolby surround (only reproduced when the source material is Dolby encoded (printed on left and right tracks as Lt – Rt)
    For the connections you should use fully wired PL cables, at least with 5 pins connected (blue wire) to avoit hiss/hum in digital amps like ice power…
    For remote control it might be possible to change your Beoremote (BL7000/5000) from 2 way mode (in Audio mode) to 1 way mode.
    All tis is quite simple and I don`t know, why nobody will tell you (?)
    Hope this helps
    Stefan
