Home Forums Product Discussion & Questions BeoSound Connect Essence MKII with old IR eye? Reply To: Connect Essence MKII with old IR eye?
#57041
Madskp
GOLD Member
So is the 5V at the IR data produced by the powered IR eye or does it come from the source (Essence or MCL2AV)?
I just tried to disconnect the IR data pin on the MCL2 AV. On the screw terminal of the MCL2AV I hav 4.95V. on the loose wire from the IR eye I have arround 2.6 volt. As I understand this type of signaling the tramitting part should try to pull the voltage down.
Where you are measuring the 1V and 0.4V could you try to disconnect the wires to see if voltage from the IR eye differes from that from the Essense?
