Dillen
If you order bearings from Danish Sound Parts, you will not need to add any oil.
They come pre-oiled, ready to mount. That also goes for the reservoir felts.
Just clean the motor spindle thoroughly, as any remains of old lubricants will be in the way,
and make sure the spindle is centered in the motor so it runs freely without rubbing on anything.
You can read more here:
https://www.dksoundparts.com/product/motor-bearings-set-for-beogram-motor-with-3mm-spindle/
