June 5, 2022 at 6:32 pm
#5683
Hi all, Christian,
i’ve ordered the parts from Beoparts and they arrived. After an afternoon struggling with the re-assembly of the cassettte transport it is now working as it should. I compared the old and the new rubbers but aside from a bit of greyness they are identical in size and shape. I think that if you were to use ‘rubber renew’ you could easily get the same results. The tolerance appears to be very narrow, just a tiny bit too little friction will drop it off.
Now it’s off to my other three decks. Not really looking forward to doing it but after this one I think i’ve nailed the process ;-).
BB
