Unless you overwrite/change the default bas redirection settings, you will have more bas from two BL9 than you can ever get with the BL19. In some cases you might achieve a better/more uniform bas reproduction in the room by keeping the 19 (e.g. in the back of the room) and by tweaking the redirection settings (have a look at the Technical Sound Guide if you want to dive into this). However this is not for ‘beginners’ and probably won’t be needed in your rather small room. Tip! Be sure to make different Speaker Groups for video and for audio listening (for this also see the Technical Sound Guide). P.S. If you don’t need surround and rear speakers in the new room, you could use one set 18’s and the 19 in another with a BS Core or alike. MM
Thanks! I had a look at the TSD years ago, I think I will get back to it as soon as I manage to set everything up.
I’m pretty familiar with speaker groups but not the very advanced stuff, it will be a chance to learn something new.
The Core is definitely a good backup plan if I realise I don’t need all the speakers, but AFAIK the Core has only a single 2-channel Powerlink output.
This reply was modified 4 weeks, 1 day ago by
Marcello.
