Reply To: Beosound Ouverture 2 external sources Y-cable?
Home Forums Product Discussion & Questions BeoSound Beosound Ouverture 2 external sources Y-cable? Reply To: Beosound Ouverture 2 external sources Y-cable?
#56618
ebnrob
    • UK
    • Topics Started 7
    • Total Posts 57
    If you’re not using the masterlink port on your Ouverture you could connect a 1611 converter to it, and plug the tape or record deck into it’s aux in. You can pick these up for about £30 on ebay. The converter would configure itself as the video master, giving you an extra source on the ouverture. Whatever is plugged into the converters aux socket will then be accessible on the TV, SAT & V.MEM sources on the ouverture.
    Rob.
